[Fixed]Default sms prog
Hi all,
I just installed Handcent sms 2.9.18 on my Hero which is alot better than the default sms prog, But i don't know how to stop the default sms prog displaying in the notification bar. It continues to display a msg as unread even when it has been, unless you use clear notifications everytime. I have tried clicking on the sms icon in the notifaction bar it takes me to my sms msg but still remains. If any one has any ideas please let me know.
If you go to the Default sms app -> Press Menu -> Settings -> You can disable Notifications and Vibrate by Un-ticking the Boxes hence you will not have that Icon appear by the Default sms app :)
**your default sms app is the one that came with the hero as standard click that. If vibrate is already ticked , Please Un-tick Vibrate first then Notifications. {Thanks to Oxomcfc for this tip} ;)
thanks a lot just to clarify for all those a bit thick like me.your default sms app is the one that came with the hero as standard click that/settings/and it would only let me untick vibrate first then notifications.if i clicked notifications first then vibrate would stay on.all the glory should go to carl c for this one.i use chomp smsnow which is brilliant lets u have picture contacts up aswell as many other things
Thank you :)
I've also Included your helpful information I've highlighted in Bold to my original post to help others { Thank you for this & Have some Rep} ;)
Carl
