Fixed My Battery Issues even with GOOD!
hoffm11
Alright, here is what I did..
Set the advanced task killer to Aggressive under Auto Kill Level
Set Auto Kill Frequency to "when screen turns off"
Changed the display to only 30%, which is very sufficient
As for GOOD for Enterprise is concerned, I changed to so I manually check my email. I don't need GOOD running while I am at working sitting infront of my computer.. ;)
Go into Preferences, click on "Connected", set to Offline
I used to have to charge the phone twice a day, but now I only charge it at night time. At 8pm, I have almost 40% battery still left!
I am moving this to the Tips and Tricks subforum.
I will say that I would advise NOT setting your task killer to aggressive (or any auto-killing at all for that matter), as it can be detrimental to the basic functions of your phone
Yeah I can see where this can cause issues, but you can put apps on the exception list too so it doesn't kill them. The main culprit for battery issues on my phone is Good for Enterprise. It has a bug that doesn't let the phone sleep.
I set ATK to Aggressive with Security to low and no ill effects. I spent a great deal of time working on exclusions and then set it to kill on screen turn off as well. it increased the Dincs in my house, battery life by many hours and I did the same for a friend with the same result. Not rocket science to rule out system services that need to run and logically auto kill things that don't.
I really hate the holy war Linux gurus (I doubt most of the people spouting the benefits of linux have ever even used actual Linux not on a phone) that get so upset about task killers despite the success of some people using them. Very frustrating to come to a forum looking for tips and see all the negative comments about tips that work.
Sounds excessive. I get about the same 40 % without doing all this stuff.
