Root fixing a corruprt, bad, missing recovery, help!
Hi,
I'm trying to reflash TWRP after a failed juopunutbear s-off process. It just didn't work out, my timing or my wire trick was bad (may have touch the metal part with my finger instead of ground...) but anyway it never worked, so I RUU'd back to stock after hboot relocking. RUUing got me back to a working phone instead of just boot looping to juopunutbear.
Then I fastboot unlock oem with my key, worked. Then
I tried to you fastboot flash recover recovery-twrp-shooter-1.1.1.img
but i get
sending 'recover' (5132 KB)... OKAY [ 1.531s]
writing 'recover'... INFOsignature checking...
FAILED (remote: signature verify fail)
finished. total time: 2.375s
Then I tried using the
PG86IMG of that recovery.
But in hboot i get CID error.
Mind you I've check the MD5 sums of all of the files before trying them, they're prefect.
Somehow my recovery partition is messed up, i'm guessing.
As of now I have s-on and hboot says its unlocked.
How can i fix or reflash the recovery? Thanks!
Do you still ahve the back ups from your s-off attempt? Also confused you said you re ruu'd so are you on the same rom you where on before when you tried s-off? If so I can help you.
go to cmd and change the directory to your s-off folder
Go into your bootloader (I think thats what its called) by turning off the phone then hold power and down volume down.
Click on fastboot
Then on the cmd prompt type this in "ControlBear -f" Then it should flash your images to your phone and it should be working again :)
Click on fastboot
I'll have to see if I do have them. If I don't would you happen to have it?
