If you have a creak in your battery door I found a fix.
And it is DUCT TAPE!!! Or electrical tape.
You can apply 3-4 one inch strips to the CENTER of the battery door, (maybe less, maybe more), and it SHOULD mostly go away, if there is still a slight give/creak, I put two long thin strips on the far side of the door along the curve (on the side it creaks).
There is still a VERY slight give/small dot of sound (not sure how else to describe this), when I push hard on this area.
There is a very slight bend in the battery door as well, but it is unnoticeable and the door is STILL as hard to remove as it was before, so there is no chance of it just popping off.
So, that is my fix.
So, that is my fix.
