How is this trolling? Have you even used flash on the Dinc yet? Seriously it sucks ass.
In the browser: menu/more/settings/enable plugins/on-demand. You'll get a little green arrow where the flash is - click it to enable all flash on the page (I think, not just the flash that you clicked).Isn't there a menu setting somewhere to disable flash? Scrolling webpages sucks now. Not smooth and fast like before.
not running the ota , i'm running skyraider using the latest leak and am having no issues with this at all.. not a crash yet, full flash 20.1, all pages work.. takes a second to load over 3g, depending on the video size, but that's to be expected and the studdering is due to web speed, not flash itself stuttering..
Also, playback is much better if you view the video in full screen mode. Sometimes this is difficult unless you zoom in on the full screen button.
As for scrubbing, I can't get it to work in full screen mode but if I exit out of full screen I can then scrub the video (though not easily).
Yeah its nearly impossible, you have to press and hold on the video to get the real fullscreen option(not just double tap like before) then go into the fullscreen and then you have to physically drag the tiny progress marker to where you want, you cant just tap on the bar. That is the only way I have found to fast forward. And that is only at one site so far.
Have a look here as well...
http://androidforums.com/incredible...-web-scrolling-fixed-update-flash-player.html
