I have an LG Optimus V (similar to the S) running 2.2. When I look in the Market, I don't see Flash 10.1 as an available download. Is there a reason for this?
Your CPU is based on ARM v6 (ARM 11). Flash 10.1 requires the ARM v7 instruction set (Cortex A8, Cortex A9, Scorpion). Your phone does not have the capability to run Flash 10.1.
The Market, for the most part, does a good job of reporting your system info and sorting apps by compatibility. You can see which ARM revision you are using under the "about phone" section. The Market sees this as well.
