Flash Beta
smfoley1
Im confused
I installed the beta but I dont see it anywhere in my apps. Is this just something that runs automatically wehen you play videos online?
are you sure you installed it? b/c when i downloaded it, i also had to open it in astro file manager, and then install it. everything works for me. but no, you wont see it in the apps section, and it will "just work" when you need it to in the browser.
and only the stock browser supports the FLASH download.
i installed it but its not working for me, any ideas on what i could have done wrong?
EDIT: it is working now, went to adobe's test page and it works now, woot!
I installed from the Market, but when I go to m.flash.com I get the "Upgrade to Flash 10.1" message. What did you do to get it to work?
I installed it from a droid life link i found on the internet, so i have flash 10.1 beta installed. it wouldnt work at first, so i uninstalled it and reinstalled it with astro and it worked. Try searching for the beta apk, that may help.
hope someone can help me out. I have an unrooted Driod. I manually updated from 2.1 to 2.2 using the instructions on this forum. I have no flash player and cannot see the download for it in the market place. I search for flash, adobe or 10.1 and it doesn't show up. What do I need to do in order to either manually install (apk) or get it to show up in the marketplace?
