Flash led..
slippknot
Member
is there a option to temporary keep the flash on?
for cases where you are trying to look for your seat number
in a darkened cinema, can turn on the flash for the light and all
thanz..
There's a widget for 2.1 I think it's called "LED Desire Light". Make sure you uninstall it before upgrading to 2.2 though as there are incompatibilities
led desire light.. hmm, ok, i'll go look for it..
flash light / torch.. ok.. will look into that too..
thanz..
since I am at it... anyone can recommend a good RPG game for desire..
itching to test its gaming capability.. hehe
Another good one is switch pro widget. It's a paid app but I prefer it coz you can have all your toggles and switches for wifi, BT, data, flashlight, profiles etc all in one compact place that's skinnable (sort of.)
Bear in mind though that by default the widget will just launch a white screen when you tap flashlight. Simply go into the widgets setting and check 'Use LED' (or something like that) and it will work perfectly with the Desire.
