rushmore
Extreme Android User
For folks having trouble with Flash, most roms need to install Flash separately- The Flash file is probably in a directory on the sd-card- open the rom zip and there should be a directory called "sd card". That will be the location on your card after installation. If you have not found it already.
For Dolphin, you have to turn plug-ins to "always active" unless you do not want Flash running all the time, of course.
