Help flash player update declined
WarningU2
I keep getting prompted to update flashplayer 10 to flashplayer 11 but it is declined. Not supported on Android 4.0.+ I have read it is possible but the different suggestions on otother sites have failed 1 is there a way and two if not how do I turn off the prompts to update.?
Yeh what is with that, I keep getting the same error for updating flash player to Adobe Flash Player 11. - "Download declined". Why isn't it letting me download???!!!!!:mad:
You can try "sideloading" it which basically means installing it from your SD card. First you'll have tho find a version of Flash Player compatible with the Incredible S, download it and move it to your SD card. Then look in settings for "Unknown sources" (usually under Security) and check it. Then you can install it from the SD card by clicking on it.
Hope that helps!
This BS is really pissing me off. Fine. Decline it. Don't give me a damn notification about it every day.
HTC Desire Z... for now.
