Root Flash player?
Status
Not open for further replies.
MrTolk3
Ok, i didn't knowwhere esse to post this so I'm doing it here. I recently got my lg motion, it is rooted and running great. The only problem i have so far besides no custom rec. Is the fact that flash player doesn't seem to work on mobile devices anymore can anybody help me out with this . I look up a video on why they were dropping it but I just couldn't figure it out. and I would greatly appreciate if somebody can point me in the direction to an alternative maybe because I can't stand this no flash bull crap
You can get flash player its really easy this are the steps i did to get flash player from the Market WITH OUT Root
step 1 go to google.com
step 2 look up adobe flash player mobile
step 3 click on the link to google play store and hit google play store
step 4 now download it :D
That's why i said sorry about this thread. I tried looking it up. I dint know why i couldn't find anything. As i said, if someone could just point me in the right direction. That's all i want
How about this, I'll close it instead of deleting it.
Also regarding telling people to search, here is a quote from the forum rules.
Site Rules said:
Also while the search feature on forums is great, and hopefully will be utilized - if someone comes here and asks a question, either answer it or don't. If you're going to suggest the search feature, be polite about it. Nothing irks me more than when I go to a forum, (and use the search!), then ask a question because I want some one-on-one with my problem, and get a simple "Use the search." reply. Suggesting it is encouraged, but don't withhold the answer because they don't.
Some people will search and others will not. If it bothers you, then simply do not reply. Nobody on this forum needs to ever be chastised about using the search. Anyway, Google is the top search engine in the world and even it misses things sometimes.
Status
