flash player
  • Start date Start date
Adobe has stopped supporting mobile flash for awhile now. It's not available on the Play Store for any device. However, adobe has all of the archived android flash player versions on their site here: Archived Flash Player versions
To install an app that's not on the play store you will need to enable side loading. Go into your phone settings: settings>apps>unknown sources
Check the box to allow the installation of the app. Download the latest possible version of flashplayer from adobe on your mobile browser. View your downloads and tap on the file you downloaded. Hit install and you should have flash player.
