my1zamboni
Member
This may be a stupid question, but I have seen a lot of talk about loading different custom kernels and it says to "flash" (***MUST FLASH DE03.TAR AND RECOVERY FROM SPRINT UPDATER***) would that be the same as putting this SPH-M900_MR2_DE03_REL_1-joeykrim-recovery-2.1.3.tar on your SD card (same as you would a kernel) then enter recovery (vol down + talk + Power) and picking it as a zip to use?
I would like to try and change kernels to some pre made I saw on the sdx site but want to make sure I do it correct.
Thank you in advance for your help.
