Flash question
lillygirl7
How do you know if you are using flash. I'm curious to know what I can do now with flash now that I couldn't before.
You can actually browse Youtube like you're on your desktop. Videos can now be played without the need of running the Youtube app.
It should be able to handle most (if not all) flash sites. Try going to m.flash.com to test it out. I'm not sure it's 100% compatible with every single flash site, but it should work with most.
