Help Flash question
J
jivephish
Guest
So does the Droid Incredible version of Froyo come preloaded with Flash 10.1? When going into Market, i cannot find a Flash 10.1 app with any keyword (flash, adobe, 10.1, etc...). When trying to install a Flash apk found from google, it says the app will replace a system app. When looking the manage applications program, under the All tab there is a Adobe Flash Player 10.1 version 10.1.72.7.
I was under the impression that Flash was a add-on available with Android Market?
I think it only needs to be downloaded by Droid 1 users. They've included it with the other phones.
According to appbrain, there is an update for flash but I can't update it because it says flash can't be found in the market.
I did the manual update (official .zip from Google) but Flash doesn't seem to want to work in the browser.
