Flash?
yes, but you have to go to google play and download it. It will work on some browsers, but not chrome
I have a Samsung Galaxy Tab Tablet 2 7.0 dara without Addition. On the box is written as an internal memory of 8 GB, but the android settings, I look at the total space to 4 GB, so to you? or should I go with him and his conversion?
Adobe has suspended support for Android from August 15, you must nanually install Flash player. So here are steps to follow:
1- Go here Zippyshare.com - android-softwares.com_Adobe_Flash_Player_11.1.115.12.apk and download the last Adobe_Flash_Player_11.1.115.12.apk
2- Connect your tablet to your PC using USB cable and copy this apk file to SDcard in "Download" (or any location you must remenber)
3- Go to GooglePlay and install any free application installer (APP installer is good for it)
4-
In your tablet go to "Settings" > "Security" > "Unknown sources" and check "Allow installation of non Market apps"
5- Finally use your APP installer to install it
Tha's all. Good luck
