Help flash
Panter
Member
My Xoom, running 4.0.4 will not play Flash based games etc.
It doesn't seem to support Flash either as Flash player does not shown in Play store. If I try and download it from the adobe site it informs me my device doesn't support it?
Adobe Flash Player (the newest versions of it) are not compatible with Android versions 4.0.3 and higher.
NO device will work, not just yours
You'll be able to see any websites and play games that use the older version of Flash Player, but as soon as they update, BLAMMO!
Wow! I assume that Flash itself will quietly slip by the wayside then? must be a reason they're not supporting it? I feel like an Apple user all over again!!!
Thanks for the reply,
Chris
Chris
There is a cracked one created by a dev on XDA, it works perfectly on 4.1
How I run my flash content is using the Mozilla Firefox browser. Install Adobe Flash .apk (simple search in Google) and properly installed that. After the install of Mozilla, head into Firefox's setting and enable plugins and....
SHAZAM!
Miracles begin happening!
