Root Flashable Fly Rom for MMX A75
satyajit2412
Features
Pre-rooted
HD Sense Network Icon
Battery Icon
Ubuntu Fonts
Supports Hindi, Telugu, Tamil etc.
Default Language is English
Transparent Sim Background
Busybox installed
Added Micromax Boot Animation
Requirements:-
1. Micromax A75 New Version ROM as base ROM (Rooted)
2. ClockworkMOD recovery by Varun/Mastermind
3. Full Backup by the recovery of previous ROM
Installation:-
Well, here are the steps
1. Download the zip from Download link
2. Dump it to SD card
3. Reboot to recovery
4. Factory reset
5. Wipe Dalvik Cache
6. Install zip from SD card
7. Reboot
Note- First Boot after Flashing, may take up to 5-8 minutes for the ROM to boot up as basic services of all applications need to fire up and make it's cache! Please be patient
Warning- (I AM NOT RESPONSIBLE FOR ANY HARM DONE TO YOUR PHONE USING THIS . DONT BLAME ME AFTER WARDS THESE HAVE DONE OWN RISK)
Credits:- Ninad, Varun, Mastermind, GTA, XDA, UOT etc etc.
--Download Link --
Fly Rom for MMX A75 - Download - 4shared - Satyajit Korlam
Mediafire Link:
http://www.mediafire.com/?5lt8767bt1440uh
Great Work! Btw this will not get the 233MB Internal Memory, This is Just the ROM everyone! :rolleyes:
We will get the around 140MB+ MB free internal memory with MMX firmware and 200MB+ free internal memory with Gionee firmware.
We will get the around 140MB+ MB free internal memory with MMX filmware and 200MB+ free internal memory with Gionee filmware.
Small correction here :)
Sir it's firmware not filmware .
nevermind everyone makes mistakes.
Is the dialer same as our stock A75 or its different please report and if anyone is using this ROM then provide a screenshots of the dialer.
the dialer is same as stock rom. there is no difference
try to change the dialer.... stock dialer is laggy..... i have completely changed stock rom except dialer..... if it will change then I will release an awesome stock rom with all features and customization :) and haan most stable, bug less rom.
u cn upload the rom ! the dialer changes cn be done by others as well ! or u cn get help as then it would take less time !
i mean its just a suggestion rest upto u sir :)
Bug: Flashlight apps don't work, flashlight works with camera apps only.
Contacts Index is based on Russian it seems.Not in English...No ext2 support.
Bug2: Even camera with flash is also not working. Phone will be hang and we need to remove battery....
is there any solution of this bug?
I really like this Rom as it is stable, speedy and with large space with masterminds trick.
best rom yet ive tried almost all roms on my a75..the only big issue is the camera it does not work please someone help!:o
If u want a similar type of but a stable ROM with all features working, then just try the ROM Xtreme made by sai vignesh... Try once and give ur comments... I m sure u'll like it...
