Root Flashback trauma paranoia
Looked, but I can't seem to find an answer to the question that worries me about flashing back from rooting; apologies if it's due to a lack of understanding on my part.
I've got a T-mobile (assume this comes under 'branded') Desire & I'm tempted to try rooting it (which I think comes under 'invalidating my warranty'). I don't want to invalidate my warranty because I'm not rich enough to replace my Desire, but I've read you can restore them to previous state ('flash' back?).
So the question:
How would I return my Desire to a branded 'T-mobile' device if I follow the guide to root it & want to go back? I mean each company brands with its own software & I'd look a bit of a pillock handing back a Vodaphone one or something wouldn't I?
I'm a great believer in identifying all the exits before I enter a room :D
if you head on over to the xda forums, there's a thread that has all of the official RUU's, and i believe that they have the t-mobile software one there.
im not entirely sure, but if you want to flash the original RUU back on to the phone, you'll need a goldcard while doing so otherwise complications arise. what method are you looking at to root?
...im not entirely sure, but if you want to flash the original RUU back on to the phone, you'll need a goldcard while doing so otherwise complications arise. what method are you looking at to root?
Thinking about using lekky's suggestion: http://androidforums.com/all-things-root-desire/70748-desire-root-guide-newbies-pc-only.html
Tbh I'm in 2 minds about rooting. Pretty sure I'm holding what amounts to a very capable personal computer that has been nerf'd by my service provider, but not at a Linux level to appreciate what it is probably capable of (my understanding of Linux is based on it having a cute penguin).
My principle query is about changing it back, & I'll have a surf through the xda forums to see what's there as you suggest.
Is that where everyone should look for their provider-specific default OS? A pity the procedure of rooting doesn't have some option to save the original state? I was rather hoping someone would say it did & I'd look silly for not realising it.
i was under the impression that once rooted, you can do a nandroid back up for recovery purposes?
don't know what actually happens when you restore this though as i've never had the need to..
the one click method is a fairly simple way of rooting, which is what i used, no goldcard was needed..
just remember mate, by rooting, you're doing so at your own risk :)
