My phone acts like its at stock. Im downloading GoSMS from market, and the notification says im downloading 38 things. My Internet browsing is bad to. Can bearly make it to 4shared to download some apk's.
Did you overclock it in the cm settings? Also you may need to reboot it a couple times to let it settle, or at least thats what it says on the wiki. I have had no such problems.
Just pull the batt, flash to stock, and start over.In market my downloaded just keep restarting.
I got it man. Thanks. MMS doesn't work for CM7 right?
I have no access to a computer. Can i still do it?
I have cwm 3.0.0.5
Alright im going to do that later. Things Can never be the way you want it lol.
You can use my fix (APN) only if you've got 4162011. If it's newer or older, You positively have to use MetrOFF. There is a MetrOFF without the "Roaming Indicator Is Off" sign though, So it shouldn't be too big a deal. I do recommend everyone use the newest one though. I'm on it and currently love it.Someone just said you can use rains apn settings and it will work. There are at the end of cm7 guide. Its worth a try so you don't have to flash 2.XXX.
I downloaded the metroOff zip. But i gave cwm 3.0.0.5. Is there any other ways to send pictures.
