i have a gs2 boost that was flashed to cricket. which guides do i need to follow to install a rom? do i need boost-specific roms or can i just use any cricket rom ment for 4.1.2, GC01?
Okay version 0.5.0 of Garwynn's kernel uses the Agat recovery. It should work fine. I am on 0.4.1 of Garwynn's kernel which uses CWM, but otherwise is the same kernel as 0.5.0
Blu Kuban!!!!! . JB 4.1.2
Lol greg really likes that Blu lol its a very nice running rom for sure
You need to flash gb27 modem
Blu Kuban is JB. Flash everything in recovery and the modem gets flashed right after ROM. No big deal.
sorry if i sounded like a dick, im trying to go with whatever requires as little flashing as possible and did not mean to sound dickish
LOL no worries man, your just nervous, just follow what greg said and it will work out fine, if he is on GC01 then he has the correct kernel and can do what you instructed and it will come out fine......
