Stradevarius
Hey,
So i'm i have regained root after latest update fiasco (for me) and have just used Droid X Bootstrapper to create a backup. my question now is how do I apply a rom? I'm looking to use liberty 1.0 but I haven't seen anywhere if I need to be deodexed for it or not, and I heard Deodexing doesn't work anymore with 2.2.1 (right?).
Here is Rooolers guide that I plan on following. Is that what I should follow or is there a step missing there that is required to be able to flash liberty?
GUIDE TO FLASHING ROM(S)
There are TWO common ways to INSTALL a ROM. here is the FIRST WAY.
NUMBER 1
1 - Download the rom of your choice and place it on the "ROOT
NUMBER 1
