I've searched and can't find this answer. I've learned a lot about partitioning, so it was worth it. Been a flashaholic for almost 2 years. I finally partitioned my SD card last week and moved to ext 3, then ext 4 in order to flash team dirt's RemICS. I'm using DT a2sd. I intalled all of my apps from Play one by one then restored their data with TB. It took a long time to get that ROM stable and load all my apps manually for a2sd to work properly. I read that Sense doesn't work with ext 4.
Questions-
1) If I want to recover one of my saved sense roms (or flash a new one) are there additional steps beyond what I've always done when I've flashed new 3.x and lower? Can I batch restore user apps with TB like I did before partitioning and moving to ext 4?
2) If I recover a saved Sense, then go back to an ICS nand, try a new ICS, or a JB rom, will I have to copy my SD card, format, partition, and one by one install each time for a2sd?
3) If I flash another 4.x+ from current 4.x+, same as 2), what's the best process to retain all SD card pics, music, etc., and apps?
As always, I thank you all for your help!
Questions-
