skarface1988
By flashing different sprint radio give you a better signal or what? I'm not sure if its true or not.
I am boot 1.04
S-off
Miui jb Rom
I am boot 1.04
S-off
Miui jb Rom
Yep. The radio that we had originally well...sucked >.> Hence why the S-Off/Radio/Evo 3D Guide.
I've noticed a better signal/slight increase in download speeds with the radio from the evo 3D Guide.
There's like 6 of them there. Which are you talking about?
There's only one version in the "fix everything" thread and that's the radio (baseband 0.97.10.0530) from an old Sprint GB build (1.13.651.7) for the Evo 3D. The PRI in that thread is from the 2.17.651.5 Sprint GB build.There's like 6 of them there. Which are you talking about?
ramjet73
I'm really not the best person to make a recommendation for VM firmware since I don't own an Evo V 4G, but if I did the version I would start with would be the firmware zip from the Virgin Mobile OTA http://androidforums.com/evo-v-4g-all-things-root/648747-update.html#post5208151. That zip file includes the current official VM radio and PRI and since you are S-OFF you can always try other radios and/or PRI's if you have issues with that.I'm thinking of flashing the pacman Rom. So which exact radio should I flash? And can you link me to it please
Do you guys still have signal fluctuations with The latest firmware?
