Help Flashing Recovery: Image not found?
I just rolled back using simple root, and before I started flashing custom roms I wanted to flash Amon RA's recovery-RA-evo-v1.8.0.img. I've tried flashing through terminal emulator, and that didn't work. I also tried flashing through adb. I have confirmed that I have root, but it's telling me that there is no image found. Does anyone have any suggestions? Thanks in advance.
Why not use the ROM Manager app in the market? It will install Amon or Clockwork Mod recovery for you right there in the app.
Yeah, I probably should've gone that route. I was trying to do it manually so I could understand the whole process but that didn't work. I flashed fresh 3.3.0.1, and then flashed the recovery through the terminal emulator. Then it worked.
