DsyMnapTic
Android Expert
Right on, yeah im sticking w CWM for now.. This install of CWM seems tp be working alot smoother than before... Thanks for all the info.. I'm gonma try ur wiping method bc for some reason i still cant wipe all my internal sd data... But i will let yall kno if i get it, but everything is great and im rocking Liquid right now, love it!
Ahh... You're trying to format internal SD....why would you want to do that? You might accidentally delete something you were about to flash
...Do as you will, but I can't inform you about that setting as I only manage contents on my internal/and external memory (SD) with a file manager.
, at least that was the case with my Galaxy Tab S. However, hit the "Mount" button and checks whether MTP is enabled. If so, hit the "Disable MTP" button. The next time you flash there will be no error.
