Root Flashing roms help
beazelgee
I need to flash my virgin mobile Motorola triumph back to the stock rom so that it is just the way it was when i got it. Does anyone know what that rom is called and where i may find it? Please help!
Hello and welcome aboard. I've moved your thread over to the correct forum hopefully to get it some faster responses. :)
Yes here is the stock rom http://db.tt/9uMMyNLf do you have clockwork installed, if so boot into recovery & wipe data factory reset, format the system in mounts & storage, then flash the stock rom, reboot should be all good. If you don't have clockwork then here it is http://db.tt/H0PE5ZwV, if you need help with how to install clockwork it's in all things root.
