Flashlight for ally - no flickering
It is shaky but then again it is the first I have ever seen that actually makes the led flash work as a flashlight. I'll deal with the shaky at least it works.:D
I havn't had a chance to test, but If I were to supply with you with some graphics for say, widget switch, would you consider using them in new releases?
Sure :) I agree with BigDaddyFromCincinnati, it is by far the best flashlight app for the Ally. I love it, and I don't mind the flickering.
I have a question, you know how some flashlight apps have two levels of brightness? Can you do that for the LG Ally?
I answered this in your topic, but sadly no, as we only have the one LED flash, and this is the only app that even works with it!
I know one of the 2.1 Velocity versions had a killer flashlight that worked flawlessly and also used the camera's flash. Like I said I dont recall if it is was .03, or .04 but I made a backaup of it and restored using Astro as it was saved on my sd card
That was 0.3 and it uses the LGHiddenMenu.apk, however the app causes stability issues in roms if used often, but yes it works
This application has made my phone unstable. Now I'm not saying its a bad program. I liked it. For some reason, though, after I used it once... first it would always restart my phone every time afterward... but then I noticed that when I went to launch my camera, it would restart also. And Gallery... and so on. I'm not sure as to why? But, after a reinstall of Velocity 1.0, no errors. I had even tried clearing dalvik cache, cache, and even uninstalling the program. Not sure what to tell you, but I do know my phone was fine before the use of the app. I hope you can figure out what it is. I really do like the light, and you did a great job with the diversity of different types of light.
The first time I tried using it my phone restarted. But after that it works great. (Besides the flickering, but I can deal with that)
Strange, Velocity 1.0 doesn't include this app. I never tried V0.3/.4 so I never had the chance to see it.
I would like to report that i reinstalled the app. This time i did not move the app to the sd and it works flawlessly.
