Help Flashlight on Galaxy 5?
Yes, You can download it.
Check the back of the phone, and locate flashlight
Then navigate to play store and search "Flashlight", click on the app and click on INSTALL, Confirm it by pressing accept.
Do watch permissions when installing flashlight apps from the Play Store. They'll need camera permission in order to operate the flashlight, and if you choose an ad-supported one it will need internet permission to load ads. That is all any flashlight app should need.
I mention this because there are some flashlight apps out there that will ask for access to the entire phone, and some of those have been caught abusing privacy very badly.
Personally I use TeslaLED - many options, no invasive permissions (not even internet), same developer as Nova launcher.
