Flickr on Hero problems
retrorom
I am trying to log in to Flickr but it does nothing... I have no connection issues, everything works fine. How can I even input or change login details for Flickr?:confused: Has anyone got a similar problem, or a solution please?
The problem is I can't even put any login details in because the loading screen is stuck at about 5%... but my wireless and my data connection are fine...
Any Idea?
i think the flickr link itself is not updated. you will notice if you go to the flickr website on your phone, there is this "old m.flickr.com" link. i'm trying to find a way on how to update the built-in flickr app. that way, it should give me the new link to login to flickr.
anyone?
I had to tell the browser not to use mobile sites in the browser settings. After that I could login to the main flickr site and People was linked.
