Root Flixster down, or not compatible w/2.2?
Redflea
Android Expert
Flixster (aka "Movies") won't connect - get a "The network connection failed. Press Retry to make another attempt."
Retry fails continuously.
Is Flixster having problems w/2.2?
Other apps I try connect to data just fine...phone shows 3G and 3 bars.
I used it last night to check some showtimes at a couple different theaters on NB 0.1 and it worked just fine. Didn't try any of the other options though so I'm not sure if that was what you were having problems with.
