Why i cant download Navionics Marine Skandinaivian East or Google Earth/maps app to my FT3. I think that any map app do not work in my FT3.
I am just the beginner whit Androids.
It is because all of the 'budget' Chinese tablets have only limited access to Market due to them not achieving Google's seal of approval for whatever reason. (there are a few theories). You will not find any paid for apps, like Navionics, and the lack of Google maps is solvable by deleting your google services framework cache data (read here..scroll down Hybrid ROM (rooted) or, alternatively, install tims 4e firmware which has google maps pre-installed.
Other nav software also runs fine...NDrive, CoPilot Live, Sygic Aura and iGo8.4 to name a few.
Thanks this is good answer.
Do you, or some one else know where i can download a marine maps like Navionics, where is sea around Finland.
I have one map preinstall (by factory)
disc010
android version 2.2-20110503
kernel 2.6.32.9
frf85b
I try update to 4e
I'm using Tim's rom.
but CoPilot Live can't download the map.
I could download the navigation voice but no map.
When I pressed the map download button. nothing happen.
I did try the other Tim's rom but it was not work.
Anyone can help me![]()
Ummm.. others have said they couldn't download maps too but I didn't have a problem...what map are you after?
I need Navionics East from market but "they" says this device in not compatible
Here is one hint from another forum but how i modify it
1. Root the device (done with Z4root)
2. Install root explorer (cannot since android market won't allow me to buy it)
3. Modify the android market fingerprint with root explorer so that the market thinks my FT3 is one of the devices in Navionics "ok to download" list
4. Purchase & Download the Navionics from market and install it.
Thank you for your advice.
but I can't purchase anymore.
I want to fix it. If I could.
Who is 'they' ?? Have you contacted Navionics to enquire if they will sell it to you?I need Navionics East from market but "they" says this device in not compatible
CoPilot version is CoPilot Live Pro v8.2.0.368
I'm trying to download Australian map.
They have a map but I can't download.
Very strange...........![]()
Navionics have an FAQ NAVIONICS: The Leader in Electronic Charts where you can request they add the flytouch into their compatability list. They also quote the pre-requisites...
So it would appear as though not all the maps are available from the CoPilot server as my copy is the same as yours...I can select the map but when I click download it just reverts to the previous screen. All is not lost though!! I have found Australsia 5.2009... not the latest but it is australia! I'm uploading it at the moment and will paste a link here when it completes..
There you go..110MB Multiupload.com - upload your files to multiple file hosting sites!
You just uncompress it and then place the 'OC' folder in /sdcard/copilot folder.
When you run copilot it might automatically just use it if you only have one map...I don't know. If not, then select menu, then the right arrow twice and select switch map......
