Root Fly x ROM Manager help
degr80ne
When I download the new rom from ROM manager and it goes to install. I wipe data and it is supposed so boot into CWM recovery but instead I get the triangle with exclamation point then I get an error..help please
Oh.. hmm I have that too actually.. if I find a solution, I'll let you know...
I'm trying to find one, but alas, I haven't yet.
*EDIT*
Okay, you may already know this... but if not, try this, it should fix it (It did for me). First, uninstall DroidXBootstrap on your phone, then download the updated one (link here). Put that on your SD card, and install it. Run it and select the 1st option. Then make sure you have Rom Manager from the market updated. Then try it again.. (Flash clockwork recov. again, download FlyX rom, wipe).
Good luck.
Thank you SOOOOOOO much vonfeldt7 !! I have been searching every forum for 2 days and get stupid answers. This works !
