I saw a few youtube videos of people successfully using their Flytouch 2 with various USB dongles. The most popular dongle is Huawei E1750 which some people said is detected as E1550.
I thought I wouldn't have a problem since I'm using Flytouch 3 with E1550 dongle:
1. I notice the "3G Settings" App this is found on Flytouch 2 is no longer in Flytouch 3.
2. I connected my dongle after doing all the APN settings in the Mobile Network setup. These settings should be correct since I use the same settings for a 3G Android phone using the same SIM card and it works okay.
3. After I insert my E1550 dongle, a small icon "3G" appears next to the battery level indicator on top of my screen. There are 2 arrows one pointing up and down that never stop flashing.
4. The blue light on the E1550 dongle just keep flashing - when the 3G connection is up, the blue light should just stay on.
Anyone successfully used a E1550 on the Flytouch 3?
Anyone managed to connect a 3G dongle to Flytouch 3? what make and model is it?
, guess you are the only one kind enough to respond. well I did some hard work googling around & it seems E1550 is supported w/o needing to unlock but i still cant get it to work
