Help flytouch 3 wifi switch
xerox77
Hello Folks,
I just received my flytouch few days ago, i did already firmware update and othr smaler adjustments, in fact this is my first tablet, but in principle i am statisfied with the flytouch.
One thing what i can't figure out is the wifi switch behaviour. When in the settings is switched on would be nice to control the wifi via the switch, but so far it does not working as i expect: when i switch it off the wifi switching off, but when i switching it on again it doesn't switching back, i should go every time to the wifi settings and turn it back via the menu.
Is it normal or maybe is there any solution around?
Thx guys!
Sorry I should've answered this one earlier. This is standard for the FT3. The hardware switch "breaks" the software switch until you recycle both. This might be fixed in a future firmware release but this is normal. Best practice is to disable wireless via the software and leave the hardware switch on(or turn it off after you've switched the software off)
