Root Flytouch3 (Odys Xtense) firmware upgrade
Michiel85
Hi all!
I have the following tablet:
Model Number: ODYS Xtense
Android Version: v2.2 2011-08-01(401111)
Kernel version: 2.6.32.9
Build number: FRF85B
on the back it has a label "ODYS Xtense"
side: 2USB, 2SD, 1HDMI, headphones, ehternet and 9V.
I want to upgrade the firmware to a android 2.3 version (because there is an app I want to run which needs v2.3)
I have downloaded Tim6a, put it on a formated sd card and reboot the tablet: boots like normal, no firmware upgrade. Have tried to press "Home" + "back" + "power", then I get the message it is upgrading, but seems like it only loads the original firmware and not the one I put on the SD card.
have tried the following frmware:
- www_apad_tv-20111001_Tim6a
- www_apad_tv-FT3-Pre-installed-Firmware-0529-no-official-release
- original superpad rom (5files, WinHex for bootable SD card)
but no succes.
Can anyone tell me the procedure for upgrading firmware and which firmware should I use for my tablet?
Thanks in advance!
