Help flytouch3 - WHITE SCREEN - its real F#?
michalole
Hi.
I bought some tablet called Flytouch 3 from Shenzgen. this is specyfication:
"Specifications:
Brand / Model: Flytouch 3 / SuperPAD 2
Operating System: Google Android v2.3
CPU / Speed: Infotmic ARM11 1Ghz CPU
Screen / Resolution: 10.2"" inch 1024x600 resistive TFT touch screen
System Memory: (RAM) 512MB DDR2
Hard Drive: 4GB NAND Flash / ( 8G optional,add $6;16G,add $17)
GPS:come with GPS antenna
Wi-Fi: Yes, 802.11b/g
LAN (RJ45): Yes, 10/100 Ethernet
3G/3.5G (HSDPA): Yes, support external USB 3G modem
Camera: Yes, 1.3 mega pixel
Audio: Built in x2 high quality speakers (0.5w) and microphone
Color: Silver, black color
Expansion Card Slot: Support Micro SD / T-Flash, Max 32GB
I/O Ports: USB2.0 host x2, 3.5mm audio jack, DC in, TF card slot, mini HDMI, RJ45 Ethernet, GPS antenna
Display Output: HDMI v1.3 full HD 1080P decoding,high-definition movie playback
Battery Pack: Rechargeable Li-ion battery 5800mAh ;Battery Life: Approx. 4-5 hours
Power Adapter: 100-220V Input, 9V DC Output, 2A
Dimensions: Approx. 270mm(H) x 170mm(W) x 25mm(D)
NET Weight: Approx. 650g
Total Weight: Approx. 1.5KG with packing box
Language: Multi-language
Game & Apps: Can download thousands of 3D games and apps by android market
Music Player: support MP3,WMA,MP2,OGG,AAC,M4A,MA4,FLAC,APE,3GP,WAV,support playlist
Video Player: Support AVI, RM, RMVB, MKV, WMV, MOV, MP4,PMP,MPEG, MPG, FLV, 3GP, MPG, H.264, etc.
E-Book Reader: SupportWORD, EXCEL, POWERPOINT, PDF, TXT, etc.....
Picture Viewer: Support JPG, JPEG, GIF......
InternetBrowser: Google Chrome webbrowser
Internet Massage: MSN, Gtalk, Skype, QQ......
Email: Yes
Special Function: Gravity inducer (G-Sensor), Android market, Google map, YouTube"
ON back of this tablet is sticker with name - infoTMIC, android 2.3 - 8GB, ddrII 512mb.
On the white box is name Superpad only (not superpad2).
the problem is when turn on power it show only WHite Screen.
I try do all buttons combination for factory reset (power, back, home - power, vol-, back - whatever), nothing work always white screen.
Also he got some litlle pond under to do reset but doesnt work.
I contact with suplier and he send me file for reflashing, so i put files on to SD , and as he say iam pusch power and Vol - buton together (should be start reflash), but its nothing happend, still only White screen.
Any ideas how to fixed?
Hi.
"Specifications:
Email: Yes
If it is V2.3 then it is most likely one of the latest builds.. possibly a Tab10. There is little known about the latest builds. If you have tried what the seller suggests regarding re-flashing the tablet and it is still faulty I would suggest you contact them again and ask to return it to them as faulty.
