Tech Addiction
Android Expert
I know it's been mentioned you can take an old set of earbuds or somthing and cut the tip off and just plug that into the T-Bolt to trick the FM Radio into turning on and use the Ext speaker. I have a 3.5mm right angle adapter that can still be used for headphones but will allow you to listen to the FM Radio through the external speakers. Thought I would share.
