Then I don't think you're looking for an app. You need a piece of hardware.i'm actually looking for an FM transmitter for my car. my stereo doesn't have an aux input unfortunately.
Does anyone have any experience with this on their OV? GOgroove FlexSMART X2 ADVANCED. This connects to your phone through bluetooth, not USB. Which means your phone's USB port is free to charge/power it while playing; this device also has a USB slot. The reviews are raving, but have not seen much from LG phone owners. My cars do not have an aux input, so this seems ideal.
My experience w/FM xmitters is it's not worth it due to the constant tweaking. When you travel you constantly have to redial to get a clear channel. And a small amount of noise signal will override your broadcast. I used to think the FM spectrum didn't carry noise. It does. If you don't travel much a FM xmitter should be OK. Roll 50 miles away from where you set freq. and chances are you'll be retuning.
I'm looking into a stereo with BT and aux jack.
I have that bluetooth adapter.
I don't have that problem with the device that's being reference, it puts out a strong FM signal that overrides any weaker FM signal; clearly a strong FM signal might be a problem.
It's a nice unit as I have one too and it will auto search for quiet FM stations, so tweaking it to another station is a piece of cake if you need to.
But as another poster wrote, it is a bit weak on the bass, not sure if that's the phone of the BT transmitter, although I think that might be Pandora's fault as music files on my memory card do sound better. For the most part I like it and it is definitely one of the better FM transmitters I've come across.
I have read reviews where they say they can hear a hissing sound if you charge while playing. Has this been your experience?
