I know, it's the least desirable solution, but i have no other choice.
I would like to ask you for an advise witch one to get.
Would be nice if transmitter had phone charger as well.
Since you already know it's the least desirable option....
Have you considered checking to see if you can upgrade your stock stereo to an aux input option? If you are a hands-on kind of guy you can DYI for about 10-15 bucks most of the time (assuming your stock stereo is capable).
Otherwise they are pretty much all the same. I'm no help on that end though.
