xNeurosiis
Does anyone use an FM tuner for their LG Motion? If so, which one do you use, and how's the sound quality? Thanks!
Yeah, just to clarify, I'm talking about the add-on FM tuner. The thing you plug into your device, and it plays your music through the car radio.
I found a transmitter at Walmart for like 15 bucks I think. But depending on the radio you have now I would suggest looking at a radio with an auxiliary in plug. I got mine at meijers for like 50 bucks and thats about what you'll spend on a good FM transmitter if not more.
Would it be terribly hard to put in a new radio? I have a 2004 Honda Accord, and the radio face (I don't know what you'd call it), seems to be in there pretty good.
