Folder contents unavailable
bryonrye
Howdy,
I just connected my Samsung Captivate (SGH-I897) to my Windows 7 PC via USB and bluetooth, and the connection works fine for both of them. I can also browse folders on my computer, but none of the files show up in the folders. It's the same for both USB and bluetooth. I can connect to my work computer via USB and don't have any problems.
Any help is appreciated. Thanks!
Howdy to you, too, Bryon :)!
Welcome to the AndroidForums.
It sounds like you might have a Windows 7 USB driver issue / difference between your home PC and the one at work.
Try looking or posting your question in the Captivate forum here at AF:
Samsung Captivate - Android Forums
I'm betting that someone has already experienced your issue and can provide some guidance for you.
Cheers and glad you signed-up with us here at AF!
Welcome to the Android Forums!
Have you tried uninstalling and re-installing the USB drivers?
