Root folders on my sd.
ashkore21
i just did the reflash to the cm7 now it wont let me view the sd on my computer threw the usb. however in the file manager i see all these folders what ones can i get rid of from befor? .android_secure .blackmarket .dataviz .android aruringtones dcim lost.dir lazylist speed software ect.. basicly what i asking is what files from the cm7 are the MUST KEEP ones so i can clear my SD. or are all files from the reflash all stored on the ascend itself
Are you pulling down the status bar and enabling usb? Don't know about the files, but a few of them look like they came from apps you installed so of course you can remove those.
+1
what he said, apps will make folders on your scard to store data, and if you dont have the app no more there's no reason to keep them folders, they are just taking up space...
