Folders, rename them?
DesireMe
Android Expert
So i've added a folder onto the homescreen and added direct message contacts to it, which is exactly what i wanted, better than the HTC People widget for me.
How do you rename the folder?
Because i'd like to call it texts and set one up for calls. But when i create another folder, it is again called "folder". So you can't differenciate between the two.
Thanks I was just about to make a thread on hero to ask this.
This works on hero as well
