Following the cricket!
RedBob62
Member
I was wondering how I could follow the BBC cricket commentary using the desire. It's a digital broadcast so the built in fm radio is no use. Nor is it available via the BBC Iplayer. I browsed to the mobile BBC site but that did not provide a link. The BBC radio 5 desktop site did have a 'listen live' option but that simply kicked off the Iplayer.
However, I found that by going to menu - more and settings you get the option to disable the mobile view. I then returned to the radio 5 site and clicked listen live. The commentary then streamed perfectly. Only problem was as soon as I turned it on England lost a wicket but I suppose you cannot have everything!
An alternative to using the iplayer is to listen via one of the radio apps such as Tunein, which I've found to give a good stable stream.
Only problem was as soon as I turned it on England lost a wicket but I suppose you cannot have everything![/QUOTE]
dont beat yourself up, england wickets go down almost as fast as the desires battery:D
i follow the cricket at cricinfo.com
260 all out, wish I had not bothered. :mad:
Thanks for the suggestions about Tunein and cricinfo, I will give them a go!
