Font Color
FrankN209
Hello,
Is there a way to change the font color on the HTC One? If so, can someone point me in the right direction?
Regards:)
Hello FrankN209. If there is a way to change the font color with a stock M8, I'm unaware. I hope someone will prove me wrong. I did want to take this opportunity to welcome you to the M8 corner of Android Forums. I hope you enjoy your time here and we are glad to have you be a part of the community.
Thank you for your help and the welcome :)
Hi FrankN209. it's possible but it requires Rooting your phone then you can install some apps that will do it. Check out the Root forums for the HTC ONE M8 for more.
