Anamacha
I would like to change the font used on my SGR -- I can't believe that Helvetica is the only clean sans font they provided.
Anyway, I have some I'd like to try; they are in .apk format. As I understand it, I have to copy those to my phone and then execute them. Then the new fonts should appear in the change menu (Settings > Display > Font Settings).
What happens if I end up not liking them and want to uninstall them? Where do they live on the phone so I can remove them?
On another forum I saw that you could create a folder on your SDcard named Fonts. But it didn't specify what format the fonts would need to be in for that to work. I assume .ttf? TrueType? Does anyone know?
thanks!
thanks!
