For android experts
ispriluc
Hi everbody, Stefan here.
I have an LG L9, Android 4.1.2 and I recently started using nfc tags. I made a task with NFC Task Laucher, to start/ stop media playback. The problem is that sometimes it starts the built in music app, and other times the xiialive online radio app, which I installed. I can`t seem to find an algorithm, it randomly chooses between these two.
What I want it to do is always start the xiia app and I don`t know how to make it the default media app. I tried to disable the music app from settings/ app manager, but then the nfc tag doesn`t do anything at all.
I know an option would be to create a different task, to start/ stop a specific app, but stop only works with rooted devices and I don`t want to root it because I`ll loose the warranty.
I was hoping there was a way that didn`t involve rooting.
Thank you for any advice.
have you tried "clear defaults" for the music app in application settings mate? Or maybe try the app Default Manager :thumbup:
"clear defaults" is blank, grey, can`t be edited. I will try Default Manager, great suggestion, thank you! I should have thought about an app that does it, after all it`s all about apps. :)
