nekogarushia
Using QPST
Hit Read from phone put your SPC
1- Go to M.IP tab and select profile 0 and edit your user name remove the "aaak." just for the first row. Should be (yournumber@mymetropcs.com)
then change the mobile ip behavior to: simple IP only
2- Go to PPP Config - and choose Um, change the user name (Your Phone#@mymetropcs.com) the password is your SPC
3- Go to PPP Config- and choose AN, change the user name (Your Phone#@mymetropcs.com) the password is your SPC
4 -Write to Phone (wait for phone to restart)
wait a few mins and your 1X/3G should be back!
Thanks for this guide http://androidforums.com/samsung-admire/454073-regarding-2-3-6-update-metropcs-solved.html I fixed my no data issue (Yes this is for 2.3.6 but it fixes the issue of 2.3.4)
