jaymzway
This just in I have read up on as last resort!
for all sandisk users only!
If you're having problems with your Samsung Galaxy S3 or other Samsung Galaxy, it could be down to your SanDisk memory card.
SanDisk has owned up to microSD cards causing problems with Samsung Galaxy phones and tablets. S3 owners and owners of other devices, including the Galaxy Note, report cards failing in both their phone and computer. Even worse, some cards continually disappear and then mount themselves over and over again, draining the battery without you realising it.
The problem affects "a very small percentage of 32GB and 64GB SanDisk Mobile Ultra microSD cards," says the memory card manufacturer. Various forums have reported the problem, including the official SanDisk forum.
"Under certain circumstances the cards may lock up and the card becomes inaccessible," SanDisk continues, adding, "the issue has been identified and a manufacturing fix has already been put in place."
Of course, the majority of users are more than happy with their Samsung phones and tablets, which are happily working away without any problems at all. But if you are suffering memory card problems, SanDisk recommend contacting the SanDisk support center immediately on 0203 3183 965.
Our Good Friend Site Owner Rob
Has provided a nice handy lil tool to android forum. Please don't forget to thank him
for bringing us a nice tool to find out which cards and phones are supported.
"Below is a website for SanDisk cards that "will work for" Other cards may work but due to compatibility issues over the software and hardware may cause undesired results!
Samsung Galaxy S III [USA] (L710/R530/R530C/I535)
Device Type : Mobile Phones
http://pct1.sandisk.com/ProductList.aspx?DeviceID=19392
For all other samsung devices go here
http://pct1.sandisk.com/DeviceList.aspx?mid=1021&dtid=6&hdnSiteID=1
For all devices go here
http://pct1.sandisk.com/default.aspx#
also look on the back of the sd card im sure it will say with in that long digit number will say sdhc or sdxc if it is legit but u will need a magnifying glass to read it n sometimes certain light will help as well
